PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 [49] 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. DD fiasco part 4
  2. i want to run straight pipe?
  3. gutted cat throwing a code.
  4. Stage 1?
  5. Spark Plugs Cofused Here
  6. Help!!! Interceptor Problem! Fast plz!
  7. Denso Iridium spark plugs?
  8. Which one of these is not like the other...
  9. stage 3 cooling
  10. Piston Help..
  11. help!!
  12. Noise coming from downpipe area..
  13. 2.8 pulley 42.5# injectors
  14. GM stage 3
  15. car lock system
  16. can the clutch hold up??
  17. H/E pump died.. help please
  18. Dropping Pulleys to 2.7"
  19. belt issue
  20. Help
  21. H/E help?
  22. wats the safest and biggest hp gain for the money
  23. problem w/ my RL, can you SS guys help?
  24. can i drive it??
  25. Bypass valve?
  26. need a little header help...
  27. Lfp???
  28. Post your project
  29. p codes on stage 3
  30. Dynoed the Harrop again today
  31. hey got a question about cel and exhaust
  32. Sateg 2 42# injector clips
  33. Gm stage 3
  34. A/F ratio gauge hook up
  35. Exhaust problem common on '05's?
  36. Fuel Injectors Question
  37. Has anyone ever...
  38. got some questions
  39. What is the smallest pulley you can put on the stock supercharger
  40. Snow performance?
  41. what should he do.?
  42. track times
  43. track times
  44. Rebel Intake Problem
  45. meth problem!
  46. hmm new goodies...
  47. Very weird random problem too...
  48. Weird Problem!!
  49. Muffler
  50. MRZ 2.0 Lightweight Crank Pulley
  51. Ehaust DC sport cat-back
  52. reliability test
  53. How do i stop This god for saken wheel hop and exhaust questions
  54. Weird knock in the engine
  55. Need A Tech Answer
  56. power guesses?
  57. what trans fluid
  58. E85???
  59. 2.2 Head on LSJ??
  60. Detailed LSJ Build up!
  61. water/meth injection hose type
  62. Meth question...
  63. Cooling duct
  64. Big problem... (Blown?)
  65. cams
  66. GM Racing cams valve springs
  67. 3in" or 2.5"???
  68. $$
  69. Stock Block??..Stock Internals??...Axels??
  70. looking for parts can anyone help?
  71. looking for parts can anyone help?
  72. best MAF sensor
  73. Do they still make Tsudo N-1
  74. O2 sensors
  75. Hurst shift knob question
  76. I need new brakes and rotors any ideas?
  77. LNF head, ecu?
  78. Ingalls in the mail..need some pointers on install (just a few)
  79. Oil pan HELP!
  80. Helpp!!
  81. Valve Train Problems!!
  82. What the heck is this/what does it do?
  83. ZEX spark plugs...info?
  84. 3 in. straight pipe
  85. S.S. header VERSUS mild steel header...is it REALLY worth the huge price difference?
  86. A question about aeroforce interceptors!
  87. squeeking
  88. gmpp head
  89. C5 Z06 Wheels
  90. Brake Discs un-even contact
  91. Tune Question!!!
  92. Thoughts on Megan Exhaust
  93. Intercooler pump
  94. 18s to 19s...
  95. Debating between CAI and Airbox mod?
  96. Car Runs hotter after intercooler and pully?
  97. Meth Question.
  98. supercharger oil change?
  99. Any Ideas on the P0533
  100. S/C Falling on its face???
  101. Ebay Exhaust
  102. tuners around springfield IL?
  103. Stage 3?? Numbers for the following
  104. I think I blew my motor looking for some opinions
  105. wheels and tires?
  106. Cooling Problem?
  107. trying to stick...
  108. Heat Exchanger Options...
  109. GM-R = Excited
  110. P0420 Catalyst System Low Efficiency
  111. Solution for code P0455
  112. deleting the rear O2 sensor
  113. Affects of ambient-air-temp on horsepower
  114. Megen Muffler
  115. How Important is the resonator?!?! NEED LOTS OF OPINIONS PLEASE!
  116. cryo2
  117. Borla or Magnaflow
  118. Loud Ticking while cold temp outside
  119. pacesetter exhaust?
  120. traction bars
  121. Alberta Exhaust regulations
  122. Buy used 42.5# injectors And use with conversion kit?!
  123. installing my ais stage 1 on thursday...Q.
  124. porting intake manifold update???
  125. 2 resonators???
  126. which turbo
  127. Quiet exhaust help
  128. wtb Supercharger
  129. click noise in rear right wheel area
  130. Meth Nozzle Size Help.
  131. Cobra heat exchanger?
  132. Time to go turbo
  133. stuck boost gauge
  134. Exhaust Sounds
  135. Blown Engine??
  136. Dfx Clutch
  137. Traction
  138. i ran a 13.9 i want to be in the low 13s
  139. bring em back vote now
  140. TB Spacer Gasket
  141. Magden Performance Computer
  142. Exhaust Restriction
  143. Ok Narrowed Down: Stage 2 or Tune?
  144. What boost are you running W/2.8
  145. Deepest muffler for a 2.0 i need...
  146. Megan exhaust problems.... engine stumbling because of it??
  147. Resonator dilemma
  148. Spark Plug Gap- Turbo
  149. getting spark plugs??
  150. small whinning humming sound
  151. Nitrous Install WOOT
  152. need help with a stage 2 tune
  153. cat/1resonator vs 3! resonators!!!!!
  154. Spoiler
  155. header?
  156. Tuning the Harrop HTV1320
  157. intake mani
  158. piston out cylinders are honed (pics)
  159. Bleeding h/e question
  160. quick question - LSJ DP
  161. Surge tank question / atmospheric purge
  162. how many tickets do you have?
  163. GMPP exhaust rattle..Am I the only one with this problem?
  164. Has this happen to you?
  165. Knock...
  166. intake mani empty
  167. Got my CX Heat exchanger..need some help!
  168. exhaust?
  169. anyone know any info on this new SC
  170. Kinda Pissed.... oh well
  171. Cooling Mod Idea...
  172. TvS pulley
  173. porting zzp header possible?
  174. Performance Aftermarket Clutch
  175. stage 2, custom pulley, self install; how's mty warranty??
  176. Header / Downpipe: Clear Image vs. ZZP vs. JBP Vortex?
  177. pulley removal
  178. Performance Supercharger oils?
  179. meth problem
  180. will 2.2 head work with 2.0?
  181. Ported Intake Manifold
  182. Z-max
  183. Hub that didn't fit
  184. Test pipe vs catless downpipe?
  185. Exhaust Cut Out
  186. I need rods (450-500whp build)
  187. The best H/E and Meth kit
  188. daul-pass vs. H/E?
  189. LSJ cams
  190. In Line Cooler
  191. Intake Question
  192. Gauging Vendor Interest Opt. B Mounting brackets
  193. i need a Twin Charger Guide
  194. broken meth kit
  195. I'm Torn between mods!!!
  196. throttle wires
  197. which clutch fits
  198. getting sick of loud exhaust
  199. I know this has been asked but i could find it..
  200. CEL light
  201. finally got my exedy in
  202. GM Racing Cams?
  203. Brake Question.
  204. Problem with Tune Or Mechanical?
  205. 10.0:1 with htv1320??
  206. Meth install
  207. injectors??
  208. JRE Turbo kit pics
  209. hptuners and wideband
  210. I have a hole in my cat... meow
  211. How much HP/TQ???
  212. whats
  213. Help with P2101
  214. brianthelion can you tune me??
  215. header bolt torque #'s?
  216. HP possibility
  217. ZZP Stage Kits?
  218. Rd Fabs CAI
  219. Looking for a good tune..
  220. Blitz Supercharger For Celica
  221. Those with the WOT box
  222. Need help with new hood
  223. injetor harness
  224. Changing M62 Supercharger Oil??
  225. Dryflow Part Number?
  226. Installed My ZZP H/E, Review
  227. best transmission oil??
  228. Twin Screw
  229. Need CEL help
  230. ruff idle, hesitation stumbling appon accel.
  231. Stainless Steel Header /dp combo
  232. Loud wine, Low exhaust noise???
  233. Downpipe Problems
  234. Questiopn About JBP Vortex
  235. a/c question
  236. Have Injen's CAI Claims Ever Been Evaluated?
  237. Show me the light
  238. Stage 2 vs Custom Setup Info.
  239. TRD Supercharger VS Eaton M62
  240. the head is off working on this car is SO EASY (NO 56k)
  241. Clutch Dilema
  242. Need contact info for someone with the GM performance Division
  243. car complete, gas mil?
  244. Stage 2 - 91 vs 93 Octane
  245. Stage 1 Cobalt ss Turbo Conversion Finally Ready
  246. Meth vs. Exhaust.... Help!
  247. 2.7 what cooling mods needed
  248. Need tool info
  249. Intake manifold
  250. The SC Belt
