- Spec2+ Clutch w/Flywheel Vs Exedy Hyper Single Clutch Kit
- Saab and Cobalt
- boost and idle problems
- cheapest way to go turbo
- GM Hub Bolt Size????? HELP ME
- 2.9 pully
- Is there a difference?
- Bad-Mab Header hath arrived!
- Exhaust Question
- Need help/ advice!
- Low back pressure causing bad MPG or need new tune?
- Car cutting out
- transmission help
- Magnaflow,Bad Mab, and XTC ,K&N Typhoon
- Pulled plugs, pics inside. Looks lean?
- crankshaft sensor code
- ZZP or OTTP
- no more hahn exhaust
- Wideband
- flex pipe replacement
- Header install Question
- Coolant surge tank help
- headlight question
- 2.5" v 3" cai???
- Fujita CAI inside diameter
- Replacing SS/SC mounts with SS/TC mounts?
- New cold air/different smell?
- motor problem
- fuel injector?
- 3 inch pulley on stock injectors...
- SC to TC
- Intake,Broken underpiece
- car sputters but wont start
- Low Coolant...6-7 times in a year...
- interceptor
- Tuning help
- stock o-rings fit the 60's?
- LSJ dipstick lenght
- Injector size??
- 2 step and nls
- ottp stage 2, trifecta
- odd occurrence after installing ZZP kit....
- Cobalt 07 SS/SC Engine Knock
- QUICK reponse needed: ZZP tensioner/pulley
- Bad wheel bearing at 40k?!?
- zzp exhaust
- P0446 & p0496
- 60's and e85, looking into opinions.
- SC needle bearings removal
- zzp cai
- Rotten eggs!
- Difference between Stage kits...
- Help me determine this problem
- hid kits
- Bolt up question
- o2 Sensor/Tuning Questions
- Couple Questions
- cam and sleeve
- backlash in drivetrain
- Tensioner pulley bolt?
- Part Number for transmission
- ok so what do you think?
- Getting tuned today
- meth question for the LSJ
- what pulley size comes with the stage 2
- Oil on belt
- stage 2 cobalt sc on e85 questions
- Few ?s bout my new car
- treadstone manifold?
- Got car back from clutch install, less boost?
- my car sounds funny!
- Injector Duty Cycle
- first perfo mod
- please help! cobalt is making me loose sleep lol
- Timing Chain Tensioner Q's.
- wondering now?
- radiator specs
- part numbers
- i know this has been asked but cant find
- tires
- ecotec eaton bypass valve
- rear o2 sensor?
- Sputtering/hesitation at higher RPMs
- Fuels???
- 20.5 psi with stage 2 pully and tune???
- need help fast!!
- HELP! Black smoke and strong exhaust smell.
- Calling all Twin Charged Cobalts!
- different fuel grades
- E85 problems
- open header
- Redline Question?
- is this a good start to mods??? opinions!!!
- Lsj guys with meth
- Idle temp? 183?
- ZZP triple Aeroforce gauges
- cooling help.
- Aeroforce Gauge Issue
- ottp 3" intake ?
- Clutch pedal stiff after hard acceleration
- Pulley Swap Question
- Is it to late?
- IC pump details?
- Fixed Problems!
- trifecta tune or hp tuners
- Quiet muffler help
- New owner, what should I buy
- Zzp s3 fmhe
- Best bang for your Buck :)
- Anyone running a header/dp with stock catback?
- Help please!!
- zzp stage 3 kit.
- Header sequence and torque.
- stupid question.... lol
- Will I need to get tuned
- How much boost can the m62 handle up too on stock everything
- Low coolant temp..what can it be?
- Has anybody else had this problem with cv axles?!?
- Meth or nitrous?
- Rough Idle
- Jbp or Dc sport headers?
- OTTP Stage 1 h/e
- Buying my exhaust soon! Last questions
- Help- Fuel Gauge question
- Dynomax Super Turbo Muffler
- Exhaust manifold heat shield
- I dun goof'd?
- Jbody Performance vortex header?
- I need the supercharger bolt guides (not sure what they are called)
- Cooling
- Rotrex SC
- 2.4 =]
- you know what? time to go have some fun
- meth kit install help
- Problem after installing custom cams please help
- replacing under the hood fuse box
- Silverline muffler Anyone?
- Flowmaster 40 series
- ordered my zzp header
- IAT's
- Another Exhaust Setup Question
- zzp connecting rods
- 2.85 pulley yes or no?
- Just bought 60s and 2.8 what else do i need
- How to replace IC Pump
- Newest Mod
- exhaust prob been asked
- p0420 ??
- shorty or stock
- whats the loudest best exhaust i can get?
- bad-mab header sound cilp?
- longtubes
- The 3 inch vs 2.5 inch debate...
- Fujita Intake installed
- My OTTP stage2 install
- Those with dualpass and opt b
- po315 and a tune? ?
- quick question
- high flow cat
- done collecting, now need to install
- want to go turbo... how much?
- Your opinion on ottps2
- 06 pcm vs. 07pcm
- pcm relearn doesnt work
- security light does not stay on for pcm relearn
- seriously WTF!!
- no power
- Indexing Sparkplugs?
- No whine from supercharger??
- fuel pump
- aeroforce intercepter/boost gauge help
- air box mod didnt work?
- knock retard at rev
- coolant
- 7k cut out
- Loud sound coming from engine
- CX racing heat exchanger question
- M62 question. Сoating of inner roots-shaft :)
- Laminova Cores
- Boost Increase question
- where to mount
- HP Tuners Demo software
- So...
- m62 rebuild ?
- Corsa Exhaust
- Just blew motor...now im gonna ask a stupid question.
- meth install
- More power with NO pulley upgrade for NHRA?
- horrible month
- megan dift spec cat-back issues
- Upgrade clutch problem???? Pls help
- zzp vs OTTP gas mileage???
- Car drives sloppy any ideas????
- Dual HE Setup
- P0068 Issue
- cated vs catless
- feeler: turbo swap...
- HELP (video)
- Build Advice.
- Anyone gone pure GMPP? just curious
- pacesetter
- wiring in dash dvd player
- Replacing head gasket in 2.0
- missfire???
- 58x reluctor problems?
- crankcase vent to exhaust benefits?
- downpipe install question
- 2.7 pulley q
- How reliable is CA Stage 2?
- 2.2 to 2.0
- Another Tuning Question
- Wideband question
- Idle Problem? No Major Mods..
- Just alittle warning when changing the timing tensioner
- supercharger coolant
- small wheel stud problem
- Film of Oil on plug #1
- dump kits
- how much louder will it be
- been told some things im unsure of
- Think I need cooling mods my IAT2 is a wee bit high check it out ! :)
- areoforce question
- p0103
- interceptor log questions
- When to tune
- need some help with exhaust
- LNF turbo mani on LSJ Head?
- got my areoforce
- 42 lb/hr injector o-rings. a few ?'s too
- Mods for a ss/sc to beat a stock ss/tc
- HaHn or ZZP twincharge
- About to upgrade clutch. Do I need a new flywheel?
- Excited!
- Any more mods?
- what to get now
- should i switch to 60lb inj
- ZZP Longtube Headers
- Stage 2 vs programmer
- E85 on tvs
- how much boost should I be making??
- hid issue again
- noise
- Pulley questions!
- Coil Pack
- So I have tried searching for Super turbo threads
- Prototype Intake manifold
- People are doing strange things to their LSJs
- ok what should i do now...?
- cannot find
