- Solid Lifters: JPB vs. Bates vs. BLE?
- zzp clutches?
- Requesting installed ZZP Intake pictures
- A ride in Ryan@ZZPs 610whp LSJ Cobalt
- How often do u change supercharger oil?
- Place your bets! $5 up for grabs!
- Tweaking GM2 with HPTuners
- Intake due to come in tomorrow
- Incase you didnt know
- ss/sc = sohc honda??
- Help please!!
- stupid lsj, makes a weird jerking when driving
- This cooling crap is gonna drive me to the nut house!!!!
- 42's and a 2.8.....
- New plans
- Part Shopping
- Boost in 1st gear?
- JBP header vs shorty
- What catback should I get?
- ZZP S3 H/E Fluid Mixture
- e85
- new to ss
- Pully Swap....
- Tranny Fill ?
- How will my car run.
- ZZP 3" intake fitment!!!!!
- when i am on cruise
- What should i do..
- Known LSJ problems?
- Best place to get new Struts and shocks LSJ
- Just got my stage 3 today
- cx racing heat exchanger
- Big Plans!!
- My zzp header and downpipe
- ZZP custom stroker motor
- Quiet Muffler Needed
- bolt up stock pulley?
- stock catback removal..
- zzp rods
- Stage 2 Supporting Mods
- This IC Pump Is Getting Ridiculous !!!
- tuning help!
- license plate
- .40 npt air bleed fitting
- is anyone in east carolina cobalts???
- More PSI???!
- Going for a Dyno Pull
- interceptor misfires
- i need help!!!!!
- need new plugs
- Autometer gauges
- IC Pump
- Missing Really bad at idle
- Stage 2 opinions-please post!!
- Newest clutch problem
- right side rear brake!
- Mileage w/Supercharger
- Where to get stage 2 kit installed? (north eastern Pa)
- ZZP vs OTTP intake.
- anyone with hptuner in berks, pa
- Hmm what next?
- Heade core
- I need advice on mods
- P1133 Code
- Quick Interceptor Question
- NEED Help A.S.A.P
- hp tuner
- question on the ttr engine mount
- Can your Cobalt do this?
- OTTP 4th Gen H/E
- Quick Question About The IC Pump
- Spark Plugs
- possibly buying zzp shorty header.
- ok so im starting cooling mods now and need help..
- Motor Build Advice
- Ecotec 2.0 LSJ Power
- Quest for Mods
- how does duall pass work?
- Meth kit for trifecta stage 3..
- heat exhcahnger ?
- difference for ls4 and lsj tb appearance wise..
- Need Help With Random Misfire Codes
- why is my car so finicky?
- rebuild help plz
- STI 20g turbo
- my custom StGe 3 overviews ..
- Vibration rear of car
- Need help removing EVAP vent solenoid
- my day at the dyno
- Missfire for the 3rd time!!!!!!!!!!!!
- Thinner radiator?
- Case Relearn
- vendors in europe??
- Stage 1 Injector size....searched?
- Critique my build plan!
- Think I need some new springs
- who runs JBP billet cams
- Rich smell
- Calling all tuners..crash course needed
- Help Needed!
- Idle bounce
- my sc mod
- get pully bolts off??
- What header?
- Exhaust hardware sizes???
- Exhaust Shop?
- nozzle size
- Clutch won't fit!?
- Got a proble
- oil psi question
- ZZP 2.9 Pulley Install Question
- LSJ Turbo Injector Size
- Installing GM Stage Two
- Shifter Cable Removal/Install
- Heat exchanger alternative
- Little help please
- Heat Exchanger Leaking?
- Helmholtz Resonator?
- Trifecta or HPTuners
- Humm help with ottp 4th gen routing
- Major lag
- Custom Side-Exit :D
- Exedy Hyper Single is good for ???
- want to upgrade
- GMPP exhaust question
- Trifecta tune?
- Lsj tune question
- fuel pump went out
- New down pipe but problem
- meth help
- Help fast!
- GMPP Clutch Install Problems
- Injen Added Today What to expect.
- Boost Question
- P0137 code. Anyone else?
- do you have to remove...
- Urgent! Need help!
- Did i put this hub on right?
- cant get belt off
- constant transmission problems
- 2.6 with 60's
- Help...losing coolant
- stock header question...
- couple of fueling problems
- ZZP CAI vs Injen CAI....Fudged Injen Dyno Sheet
- is it dangerous ?
- Would this work!!!!???
- injectors
- cam postioning sensor?
- lsj supercharger belt
- ss and ss/sc have the same brakes
- Front end problems ?
- lsj weght reduction
- Bye Bye TVS!!!
- problem
- Worked on a Twincharged last night
- OEM Shift light
- AEM dryflow filter on ZZP 3" CAI
- sticking brake pedal?
- New to cooling mods. Few ?ions.
- Custom tuned stage 2
- Look what arrived in the mail...
- Weird "clacking" noise
- Parts for sale
- Orange Goo In My Intake Ports
- which hub?
- stock muffler gmpp sport piping???
- ottp stage 2 tune questions
- Goin to the OTTP stage 2 kit and got a question
- difference in catbacks
- where to find ic pump?
- best guess radiator damage
- H/E Coolant loss help
- need a header???
- internals
- Mid-length or Long tube header?????
- Dual pass Otion B
- Electric Power Steering - FUSE!
- No cel???!!!
- will this hurt car?
- RPD unit
- pacesetter header
- HP Tuners help. What the hell do I have to buy?
- 2 slight issues
- M62 gasket???
- 2.8 and 60's???????
- Coupe Orange wingless trunk lid ebay
- My spark plugs after 225 miles on a fresh motor
- Wa kid of spark plugs?
- Will it take 110 stock?
- What will it take?!
- guys help me
- PCM advice
- Please help
- info stage kits
- System 2 lean & Cyl. 2 Misfire
- wideband or afr gauge?
- turbo lsj alternator pics. welded
- ZZP Intake
- how long for a stage kit to get in?
- Muffler swap
- Aftermarket Radiators
- Modifications
- Stage 2 Heat Exchanger
- NC/SC Tune
- intake with meth port
- Need some help about stage kits
- Spark plugs needed?
- Post pics of oil line tap
- Massive oil consumption issue (pic inside)
- Oh Yes!!! Yet ANOTHER meth question...
- Balance Shaft Delete Kit
- Weird problem when starting car..
- Review: ZZP BRFS
- I have an EVAP issue and search is down. Help.
- PLease help. my belt keeps snapping
- porting blower and tb
- Several Engine Problems
- how reliable has your balt been
- Problem: car shakes left to right under accleration????
- would this be a good setup?
- laminovas for single pass???
- GMPP Exhaust
- clutch advise
- Time to upgrade need some help please.
- supercharger inlet pressure
- exhaust question
- valve cover
- LSJ Turbo Problems
- Quick LSJ Mod advice
- Changing pulleys?
- Heat Ex removal..
- How much should this help?
- Heat Exchanger
- I have a question
- where can i get an 07 ecm for cheap?
- Vacuum Question
- So what next?
- Have a question
- Will It Fit?
- honed manifold or ca v2 header?
- please help
- Hahn turbo kit
- Where to get a Crank Relearn?
- Is this GMPP clutch?
- havin a few issues. need help with em all
- Pedder spring and TC kit for sc
- trifecta+gm stage 3
- Heat exchanger ?
- Heat Exchanger to stock he diagram
