PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. what can i gain ?
  2. Anybody running the GM LSJ Clutch Upgrade Kit?
  3. Lookign for a detailed how-to on changing the stock pulley and wirign up 60lb injecto
  4. Baseline Dyno Results
  5. Looking at options like fuel injectors, torque damper, and pulley
  6. Looking at options like fuel injectors, torque damper, and pulley
  7. Looking at options like fuel injectors, torque damper, and pulley
  8. help with stage kit
  9. Need brake rotors
  10. Hahn 3 inch installed, vibrations?
  11. quick question about my heater
  12. Is an Lsj backwards comaptible with a cavalier?
  13. 3" exhaust
  14. Flexpipe Cracked Again
  15. StevesBlack06 LSJ build (round 2)
  16. steering rack or inner tie rods.... i found some
  17. cam angle sensor
  18. Snaped an Axel tonight!
  19. How much will zzp header/DP help me?
  20. E85 and 91 mix
  21. Throwing code and shaking
  22. Raffle tickets for TVS
  23. So question
  24. Advice Please ASAP: Wiil be buyin this Sunday and have a question about a SS & ION
  25. rebuild
  26. Turbo Kit for LSJ
  27. Why hasnt someone re-engineered a STS...
  28. Where can I get this?
  29. How can I tell if a Cobalt SS has been modified with pulley
  30. check gas cap code?
  31. Wtf is going on?
  32. B&M or TWM Short Shifter?
  33. next upgrade 2006 ss
  34. WOT BOX Does It Really Hold Boost?
  35. P0300: Plug, Injector, or Tuning???
  36. Need help, strange problem
  37. Those with a Lightweight Flywheel
  38. Just purchased a 06 Cobalt SS what mods to start with
  39. Brake Problem
  40. Bad News...
  41. best exhaust
  42. ls4tb to injen cai coupler where?
  43. Does this sound like a transmission issue?
  44. cabin air filter???
  45. Question?!
  46. anyone have a junk head?
  47. Stage 2 and Injen CAI 1/4 times/questions about performance.
  48. camshaft actuator solenoid
  49. mod questions
  50. CEL question
  51. Stock catback vs aftermarket
  52. Fuel Pump
  53. crankshaft sensor
  54. Boost vs MAP
  55. RWD COBALT. What happen to it?
  56. help...
  57. Average cost of exhaust install?
  58. jbp valve springs
  59. I need a stock 07 ss/sc file
  60. blew my engine sunday
  61. Should u go 3" Intake???
  62. Exhaust Louder then normal
  63. Rough Night!
  64. how do i remove rear seats
  65. Best Injen Intake Price???
  66. Steering column gauge pod
  67. cobalt ss/sc temp gauge
  68. LSJ turbo guys question for you!
  69. i have no speedometer
  70. Airbox mod
  71. Only doing 22mpg!!! Help!!!
  72. deer hit!!!
  73. need help
  74. Help me order my stage kit please!
  75. New Member!
  76. Testing Intercooler Pump
  77. Clear Image Header and dp with Hahn catback. Opinions?
  78. Throwing Codes Please HELP !! ! ! ! ! ASAP SOS lol
  79. Help with HPT
  80. headgasket and ARP studs; Need some guidance
  81. oil cooler and balance shaft delete issues
  82. Road racing boost problem
  83. New Owner
  84. P068 engine power reduced
  85. Nitrous input please!
  86. cobalt addiction injectors and others
  87. Evap Problem possible fix....
  88. really weird problem need help asap
  89. Quick and easy question
  90. Heat Exchanger Install Question
  91. Emissions Canister Purge Solenoid
  92. Removing Intake Manifold
  93. Supercharger malfunction
  94. Spark plug gap for 2.8"
  95. Longtube header?
  96. Trunk picture NEEDED!
  97. future mod plans
  98. LSJ guys tired of cramping your hand to change an oil filter?
  99. Will this header work?
  100. intercooler pump part number?
  101. need some whp help
  102. theory behind option b??
  103. Car wont start
  104. I need an exhaust
  105. zzp stg3 kit
  106. 80lbs and e85 problem
  107. Engine Rattle - 2007 SS SC
  108. New PB with my twincharge setup
  109. E85 supercharger pulley question
  110. Anyone interested in Hahn Stage V kit swap for Supercharger?
  111. 12.999 with mods?
  112. exhaust
  113. ZZP Billet Motor Mount A+++
  114. What Difference in exhaust piping?
  115. ottp stage 1 or gm stage 2
  116. ottp stage 1 or GM stage 2
  117. Colder plugs
  118. vibration in the gas pedal and wheel?
  119. KR at acceleration>??
  120. 90k miles and still kickin
  121. Supercharger porting question
  122. any difference between gms2 and gms3 reflash?
  123. p1133 question
  124. Alcohol instead of coolant???
  125. misfire
  126. maf performance code?
  127. lack of power?
  128. Setting up mod list
  129. WOT Position wire Hookup read more...
  130. My build:
  131. Need cooling mod
  132. N2O Wet Shot 50 Or Dry Shot 50
  133. 158 mph pic
  134. twin charge
  135. 2006 SS/SC Issues
  136. A noise when the car is shut off
  137. 2.0 LSJ Head part number??
  138. 79lbs and 80lbs whats the difference
  139. N2MB dual feature
  140. Thinking of cutting the silencer
  141. Finally got the Cobalt SS 06
  142. Interesting Twincharge Dyno Testing
  143. How do these plugs look? ***pics inside***
  144. E85 fuel mods
  145. DP for Pacesetter header
  146. sqweak with new pulley
  147. stock psi on ss/sc
  148. Pushing MORE MODs
  149. i might sound stupid
  150. anyone:NO LIFT SHIFT
  151. high compression pistons
  152. Cobalt Addiction V2 header?
  153. GSP Axles anyone?
  154. Short header?
  155. p2261 HELP!!!
  156. help with tsudo exhaust
  157. Interesting situation
  158. Pump Going bad?
  159. New engine...
  160. New OTT Heat Exchanger
  161. Idle, Driving, Accelerating, all kinds of issues Plz help!
  162. LS4 TB - Idle Question - Vacuum?
  163. Twin screw supercharger
  164. TVS Build up
  165. Various SS/SC Torque Specs/Ratings
  166. Supercharge coolant pump
  167. keeping stock muffler
  168. P0171 on e85
  169. Pacesetter header
  170. black bow ties ?
  171. Just to be safe
  172. E85 Experts
  173. Aeroforce Interceptor question...
  174. Random knock due to plug?
  175. CEL with no error code, tried to search..
  176. E85 on ottp setup
  177. E85 on ottp setup
  178. can I use a lq4 tb
  179. Custom Exhaust System
  180. what will a new trottlebody or a bigger one do for me?
  181. LNF intake mani + lsj= Proper fit??
  182. LSJ head and 2.2
  183. will guage still be accurate
  184. guages
  185. I have a damn hesitation problem that I can't find why it's happening!
  186. bad plugs? dirty tb?
  187. guage pillar
  188. Extra Quart of Oil, Big Problem or Not?
  189. when should meth come on
  190. hahn catback install help
  191. new engines
  192. Has anybody tried OBX LSD for SS/SC?
  193. blot on mods
  194. Need a tuner
  195. GM performance
  196. Need opinions here people
  197. Option B from OTTP everything I need?
  198. hid wiring questions plz help
  199. need help asap
  200. brake squel
  201. The deal with dex-cool?
  202. rust check
  203. Boost for a 2.6 sc ported
  204. :) about to put in
  205. Heat exchanger install?
  206. Gas question
  207. Exhaust leak affects?
  208. Buying New Clutch and Flywheel
  209. Lisense plate light
  210. Brakes on the cobalt
  211. need a part number
  212. Ac
  213. help
  214. overboost problems
  215. Spark plug gap for TVS 80mm
  216. auto transmission mounts & auto engine mounts
  217. Cat CEL Poll
  218. ?
  219. Looking for spark plugs
  220. Wash and wax
  221. i need some advice
  222. downpipe
  223. Exhaust ideas
  224. Need help with meth kit
  225. found random part in engine???
  226. Crank relay HELP!!!!
  227. piston
  228. How much is 80 kPa
  229. O2 extender
  230. e3 plugs
  231. help
  232. new exhaust installed
  233. Air Fuel Ratio. Sensor Mounting Trouble.
  234. Air Fuel Ratio. Sensor Mounting Trouble.
  235. making a kit needs some info
  236. Knock and GM Stage 2
  237. help building motor specs
  238. Anyone know if these injectors work
  239. Tennpenn83 vs. WickedSS2005 (TVS vs E85 M62)
  240. axels
  241. Ottp stage 1
  242. Mandrel exhaust system
  243. 2.7" Smoothflow pulley, have to use a hammer to put it in place... is that normal?
  244. Bought New Spark Plugs. Need Some HELP
  245. oil?
  246. fuel dilivery problems
  247. Transmission Flush...
  248. need a lil help here
  249. serious help need plz
  250. trans mounts
