PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. help please is this for real?
  2. what's your average temp going down the highway?
  3. My car dripping oil everywhere
  4. Very Simple Question
  5. springs
  6. widest tires on ss s/c
  7. HOLY CRAP look what I found IN my pulley! must see
  8. exhaust cutout...
  9. mod questions
  10. Question About GM Stage Kits
  11. squeeking noise rear left area
  12. Fujita/stock airbox mod idea.
  13. 2.0 lsj conversion questions
  14. Short throw shifter
  15. Clear Image Catback Exhaust
  16. misfires
  17. Some ?'s
  18. Valve cover breather/ PCV Hose removal
  19. Winter Storage tips
  20. Cooling mod: Killer Chiller
  21. CEL-need some advice please
  22. I think i have belt slipping issues, thoughts?
  23. Fujita air filter size
  24. help please P0300
  25. How safe is meth injection on the LSJ
  26. ? about DP gasket leaks
  27. Fram Air Filter
  28. clutch slippage :(
  29. Engine Reduce Power Help!!!
  30. size of screws
  31. want to buy some stuff
  32. Can some one finally clear this up for me?
  33. Cruse control problems
  34. How Many Guys Are Seriously Going Turbo Conversion
  35. Alot of exhaust questions. Help me outttt!!!
  36. Need a catless downpipe
  37. Exhaust Removal
  38. Dual Aeroforce Interceptor?
  39. best mods
  40. The Nitrous Question
  41. 10:1 on high boost
  42. sfphq 2.9 with gm hub?
  43. Dual pass vs Cobra heat exchanger
  44. OTT Stage 1 Almost Installed
  45. solid engine mounts or traction bars??
  46. what is the maximum gas mileage?
  47. compression test help
  48. Bwoody vs TTR vs CA
  49. Tire Rotation (Stock Pirelli's)
  50. Power Mods
  51. Canadian (export) Stage III TSB
  52. Spark plugs
  53. SS/SC throttle body
  54. Dyno numbers
  55. Lsj engine
  56. Cat-back exhaust - Which one??
  57. Question?
  58. SC Silencer holes
  59. Fmhe Intake Numbers
  60. lol!
  61. performance shops in kansas
  62. Oil leaking from engine, need help to figure out where it's coming from
  63. Future engine block build descisions
  64. Fac. Tach slow
  65. Time To Mod!!!
  66. Feedback: WOT Box. Worth it?
  67. Intense Racing....
  68. Will DR's Snap axle easily?
  69. hatrickstu mod container options?
  70. Stock LSJ Boost Gauge
  71. Megan Racing products?
  72. SLP header question
  73. belt slipping
  74. Car dying
  75. 05 Stage 2 Help
  76. CAI add
  77. pulley/injectors question.
  78. 42lb Injectors
  79. Cant log or write VCM????
  80. SLP with Header/DP
  81. Fuel Pump Noise
  82. Boost gauge not moving
  83. Hey need help
  84. ott stage 1
  85. Vibrant Street Power Cat-Back
  86. front mount H/E question
  87. 60# injectors
  88. Stage 2 problem - low hp
  89. Does ne 1 have zzp twincharge kit?
  90. New ECU Questions
  91. LSJ Intake Manifold is the Problem....ARE YOU SURE?
  92. injectors-stock
  93. Low coolant issues
  94. Opinions on ZZP Stage 4 kit?
  95. I just installed the ingalls stiffy problems
  96. intercooler piping 1200 bucks
  97. Shifting points
  98. intercooler piping 1200 bucks
  99. what did your CAI rasie your boost to?
  100. clutch problem
  101. Odd Belt Squeak.
  102. Rattle in first
  103. ????
  104. Trading in the SS/SC fo TC
  105. Front o2 sensor
  106. confused about dealer
  107. zzp vs vibrant
  108. pullies for gm hub?
  109. Next step for power?
  110. Gm Dual Pass End Plate For Sale Never Installed
  111. put on a zzp's 3" catted dp & have a problem
  112. plug question
  113. intercooler pump leaking after install of "hattrickstu" mod......ideas?
  114. Don't know what to buy???
  115. how much boost?
  116. which magnaflow muffler?
  117. I/C Pump and funs on Acc
  118. CAI install walk through
  119. looking to go turbo?
  120. My coolant Went somewhere.
  121. Need Cat or No Cat?
  122. Looking at headers
  123. Starting problem
  124. Help with a header
  125. For those with ported heads....
  126. dyno day
  127. Anyone else have this problem?
  128. LS4 throttle body and intake discussion
  129. Winter Toys.
  130. Laminova Flow direction.
  131. clutch kits?
  132. car surging between 2k to 3k rpms
  133. 2.25" piece of exhaust delete
  134. what mods to go with???
  135. cam question
  136. Winter Goodies List
  137. exhaust cutout???????
  138. supertech question
  139. What clutch should i get?
  140. Trying to clarify a few things with the LSJ intercooler system...
  141. Anyone turbo without LSD?
  142. Questions
  143. Finally 13s!!!!!!!!!!!!!!!!!!!!!!!!!!...... :)
  144. Cobalt Shift Knob
  145. exhaust question
  146. Sputtering/Missing?
  147. where do i go?
  148. port and polish supercharger?
  149. Spec clutch question
  150. stage 1 tune ?
  151. new bermbo brakes
  152. Ram Air upgrade to short ram ftw
  153. CA HE measurements ?
  154. intercooler pump, aftermarket options
  155. aftermarket boost gauge ??
  156. needdd answer asap????
  157. eaton m62 oil change
  158. what u think about this for a trade in
  159. too much s/c oil?
  160. need a part number
  161. Weird Acceleration Problem!!!
  162. Maybe Blown Up?
  163. Warm Up time
  164. traction control kit for cobalt sc
  165. Stock exhaust pipe size?
  166. Cat question
  167. Gauging VENDOR INTEREST!!! SINGLE PASS MANIFOLD
  168. Idle problem...missfires
  169. 60# injectors on Stock SS/SC
  170. tvs min requirements/min power gain
  171. 1 Step Colder Plugs
  172. Vibrant Resonator or Magnaflow Muffler...opinions needed!
  173. fuel system install
  174. *BilletFlow End of Summer SALE*
  175. Radiator...
  176. need help plz
  177. runs like crap
  178. JBP Vortex header exhaust?
  179. Blowing out exhaust gaskets = high egt's?
  180. Full exhaust question
  181. Custom intake manifold thoughts...
  182. putting motor back together... got a question for people who have done this before.
  183. OEM Trans Fluid
  184. Motor is dead...Build time!!
  185. My turbo build thread finally!
  186. My oil smells like gas!
  187. Aftermarket intake manifold
  188. **HELP** Vibrations-buzzing
  189. What should my next mod be?
  190. MAF question
  191. Auto parts store fuel filter?
  192. rebuild opinons
  193. Weird noise from supercharger?
  194. Alternator pulley removal
  195. Got A Problem 230whp?
  196. 30 lb boost guage
  197. 42's to 60's
  198. Injector install..
  199. Stage II questions
  200. installed wideband, questions on afr's
  201. JBP header anyone have this?
  202. ZZP Heat Exchanger
  203. anyone on the OTT pcm?
  204. Exhaust Pieces
  205. oil feed line hookup
  206. insomnia thinking....
  207. Weird Problem
  208. I Got a Free Header...
  209. supercharger oil change help!
  210. Help, oil filler cap filter
  211. Tuning question
  212. boost gauge install
  213. Fuel line pressure test valve. Black cap?
  214. Timing?
  215. Who does have the highest coolant temp?
  216. Denso copper plugs
  217. Has Anyone Bought A Tuned Computer??????
  218. Altiery54 made it out to cordova today..
  219. Aftermarket Turbo Manifold
  220. just installed heat exchanger
  221. DD fiasco 5 w/pics
  222. Compression Ratio: 10.0:1
  223. meth injection pump install
  224. my header and custom downpipe
  225. Washer fluid resevior as coolant tank....
  226. supercharger oil change attempt
  227. I got a CEL and then it dissappeared!!!
  228. Lots of misfires, is this normal?
  229. Transmission FLuid
  230. aem boost controller
  231. CAI maintenance?
  232. PCM Conundrum
  233. 2.8" pulley on stage 2 injectors...
  234. Anyone know if the LNF exhaust Mani works on the LSJ?
  235. Problem with interceptor gauge...HELP PLEASE
  236. Shorty or Longtube Header???? Need help
  237. ZZP Heat Exchanger
  238. megan exhaust owners!
  239. 42 lbs injectors
  240. Pulley and hub
  241. A quick question..
  242. Question about upgrading to 60# and 2.8
  243. Good tuners
  244. connecting rod?
  245. Over The Top Performance 60#s
  246. High Flow Cat on stock downpipe
  247. Need answer bad
  248. Methanol Injection and Spark Plug Temperature (a Question)
  249. Can stock axles handle head work??
  250. Header Wrap question
