PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. What is size stud on GM Adjustable Cams 3/8 or 5/16?
  2. Looking for a tuner in St. Louis MO
  3. Valve Lash Adjuster & Low Valve Lift on build
  4. Hey guys
  5. Endurance racing LSJ Miata Swap
  6. Baja Bug LSJ Rebulid
  7. Intercooler pump inlet/outlet
  8. Blocking leakage ports
  9. Fuel Ignition Map for modified LSJ
  10. Laminova core swap
  11. Setup question
  12. IAT 2 temps
  13. Threw a rod today
  14. Stage 2 ported Supercharger
  15. Is the LSJ oil pan a bad design?
  16. How to check hex drive timing on aftermarket cams
  17. Lsj E36 bimmer!
  18. Need new spark plugs
  19. Oil cooler for the M62
  20. Need an engine
  21. ZZP Turbo Swap Still not running(VIDEO)
  22. Anyone bleeding both the Heat exchanger and Lamanova Manifold?
  23. Can't figure out this miss fire / idle issue
  24. O6 pulley and injectors
  25. Starting rough
  26. ZZP Turbo Swap Wont run/data log file attatched
  27. Rebuilding a purchased LSJ
  28. How well do they age?
  29. stock intercooler fluid flow
  30. Boost waaay high
  31. android app for IAT2 data?
  32. intercooler pump pig tail or not
  33. 2006 Cobalt Ss Supercharged
  34. Rebuild Time
  35. 2006 Chevy Cobalt SS supercharged bad exhaust
  36. GM STAGE 2 tune
  37. Balance Shaft Elimination GMracing part XGH676
  38. ZZP PCM 1.0 Tune is the real deal.
  39. engine fuel/ignition map for new build
  40. Chrankshaft Water Pump/Balance Shaft Sprocket. Why 2 pc and adjustable?
  41. Has anyone used the zzp timing chain kit??
  42. Eaton TVS2
  43. zzp s2 tune vs gm s2 tune
  44. Charger Port
  45. Fuel pump upgrades?
  46. MPx 3.0 Cat-Back on LSJ?
  47. Intercooler routing pump location-dual pass
  48. zzp turbo swap problems
  49. Replace Stock H/E with Cobra H/E? Issues?
  50. Anyone ever try to run zzp stage 3 on the stock clutch?
  51. ebay header/downpipe
  52. bought 2007 ss sc
  53. Option b tank
  54. Super budget build Redline
  55. LSJ Custom Exhaust
  56. 2.8" vs 2.9" pulley
  57. 315ss #HondaHunting Lsj
  58. Dropping from 3.0 to 2.9 Pulley
  59. +2.5mm Intake/Exhaust LSJ Valve Upgrade
  60. .83 turbine housing s200
  61. Pcm
  62. Possible new Supercharger cooling mod?
  63. Methanol/Water injection between SC and IM
  64. 1/4 mile record for stock interal LSJ-T
  65. NBS vs Balance shaft delete
  66. Anyone know why this spring is here?
  67. Needing help with timing chain 06 cobalt ss/sc
  68. 600whp tvs build round 2
  69. Heat exhanger setup
  70. Gicing Credit where it's due- the for the help
  71. Porting lower intake manifold
  72. Bass_Waves most indecisive build thread ever
  73. LSJ MAF in 2.5" pipe
  74. Lsj dorm room build
  75. Tuned question on supercharged
  76. Racing clutch
  77. Stock Boost
  78. Where do i get a stage one reflash and injectors.
  79. TVS with 2.7 Pulley
  80. Anyone have install pictures or guide for old style zzperformance brfps
  81. LSJ-T BPV or BOV & MAF questions
  82. Stage 2 upgrade
  83. Hydroshield for ZZP CAI
  84. Cobalt ss Sc
  85. True long tube race header
  86. ZZP midlength header & downpipe
  87. Heat Exchanger Dimensions
  88. TVS 1900 Blower
  89. LK9 manifold modifications?
  90. IAT2 Post-supercharger general readings
  91. Joel's 07 Redline K04 Turbo Build
  92. Installed stage 3 and now no spark
  93. Phenolic spacer
  94. Twincharged?
  95. Dont think these plugs are good anymore
  96. Pulley help
  97. Tuning
  98. AEM Performance Websites
  99. P0069 with stage 2 kit
  100. Lsj ported head and valve work anyone here has it?
  101. Help please good deal not sure ??
  102. Piston and rods
  103. GMPP Clutch' In Stock
  104. Lsj rebuild
  105. Best setup for factory Supercharger?
  106. Well I finally did the air box mod and now I enjoy the wet weather.
  107. "Floating" RPMs? Shifting resistance? (06 S/C)
  108. Cobalt blew up
  109. k04 setup on a LSJ
  110. Project OEM
  111. Is this a good clutch?
  112. Ecm and pcm
  113. ZZP BRFPS,...help :/
  114. Size of supercharger bolts?
  115. Oil spitting out of exhaust at idle
  116. GM Stage Kit Reflash, any difficulties from dealer?
  117. throttle position
  118. Cobalt SS/SC 07 Help needed please!
  119. Rear SC needle bearings
  120. GMS3 and aftermarket CAI
  121. 400 HP Goal Suggestions
  122. LSJ with L61 build (crank sensor???)
  123. Injectors
  124. Stage 1 question
  125. Supercharger coolant addditive question
  126. Can someone find out roughly how much HP I should have after these performance parts
  127. Turbo LSJ to Gen 3 complete rebuild thread
  128. More Induction Noise After Vibrant Mid-length Header Install?
  129. Is it modded?... Or NAH??
  130. [Work In Progress] Can I delete the rear 02 sensor in the downpipe? URGENT, thanks!
  131. Let's Spice Things Back Up In Here. S257FMW Turbo Time
  132. Air Box Mod Question
  133. ZZP 2.5in cat dp with borla muffler install
  134. NEED ADVICE on ZZP stage 3 kit
  135. When does the factory fuel system max out?
  136. Only getting 3lbs of boost
  137. Cylinder head part number
  138. Should I pick this up???
  139. Upgraded ARP timing bolt install
  140. Phase 5 listed for sale. Engine and suspension tech.
  141. LSJ valves
  142. What 02 sensor should I run ??
  143. P0133 trouble code after ZZP shorty header install
  144. 9000RPM's and P0606 Engine power reduced and ENgine disabled
  145. Engine upgrade
  146. Timing chain kit dnj reviews
  147. BPV opening up at full boost
  148. B207R Swap?
  149. HP Tuners Remote Tuner
  150. Supercharger, Methanol/water injection location
  151. CBM-10813-Ecotec LE5 remote oil filter adapter
  152. WVU_SS goes turbo
  153. ATI super damper (over-drive)
  154. Long time no see. Questions on GM Stage 3 PCM
  155. Pull engine or not.
  156. ZZP HEADER Manifold GASKET ???
  157. LSJ I/C pump harness question
  158. new fuel pump, 85psi fuel pressure
  159. Plug index direction.
  160. Ricklovin's Build Thread
  161. What's the normal A/F for e85?
  162. ported cyl head questions
  163. LSJ-T questions
  164. Need info on engine swap
  165. What caused this sleeve damage
  166. Looking to get a little extra power
  167. Murdered SS Build
  168. Shaving a few pounds off flywheel
  169. Safe to resleeve an LSJ?
  170. Kobraa's build thread
  171. after stage 2 where do I go?
  172. help! need ideas for mods on my 07 cobalt ss.
  173. turbo lsj wot box misfire
  174. Well it has happened...
  175. LSJ 2.9 Pulley
  176. Questions about rebuild
  177. Lsj-turbo questions
  178. How much boost can a stock lsj block cylinder walls handle
  179. Relocate coolant reservoir for custom intake
  180. Question about exhaust
  181. robertmichaels goes to the dark side (LSJ-T)
  182. OTTP turbo parts
  183. what springs for stage 1 ottp turbo cams
  184. Newly purchased 07 Redline: how to tell what mods have been done?
  185. 42# injectors work on stock setup??
  186. Will this resonator fit? Vibrant Ultra Quiet
  187. Turbo swapping with lnf parts questions
  188. turbo swap and e85 question
  189. looking for cams/ selling stockers
  190. Haven's build thread!
  191. GTX3076r powered LSJ
  192. Muffler
  193. Swapping pulleys question
  194. Need help with laminovas and intake manifold
  195. M62 spacer plate- zzp
  196. 2.6 or 2.7
  197. TVS Install Question NOT MAP SENSOR RELATED
  198. How can I get the Stage 2 factory tune out back on?
  199. ZZP Heat Exchanger with Dual Endpass and Option B
  200. m62 bypass valve vs m90
  201. LSJ-T Swapped Cav Build
  202. Holset lsj v2
  203. Lsj-t intake manifold
  204. can 42s support cams and 3.1
  205. Ballin' on a budget exhaust idea
  206. obx fuel rail
  207. ALMOST back...
  208. Intake
  209. OTTP longtube header help
  210. BoostedLemonPies official "coming off the jack stands soon" build thread
  211. What pulley is this?
  212. Belt Lengths and part numbers for the Lsj
  213. First mod question after HP Tuners.
  214. Worked S20G or S256et?
  215. Zzp header and dp
  216. 2006 SS/SC Mod Help
  217. Injector type
  218. Can I have both.?
  219. Supertech vs OEM valves
  220. Gen 4 Lifters: Closer Look
  221. Finally Stage 2!
  222. LSJ Springs, when do I need solid lifters?
  223. mods
  224. still at it
  225. Want to go stage 2. Need help
  226. Question for the M62 experts
  227. LSJ LTH, Catless DP Muffler Delete?
  228. Stage 2 belt and 2.9" pulley?
  229. ZZP stage 2 + original clutch
  230. even worse day!
  231. Newbie: Need help with exhaust!
  232. How to time the cam sensor housing
  233. lol BAD day at the track!
  234. Exhaust ideas.
  235. 06 lsj intake mani gasket and blower gasket
  236. Why am I getting a flood of requests to tune for Nitrous?
  237. Methanol pressure switch? and bonus questions..
  238. 60# injectors on lsj
  239. e85 & nitrous mix?
  240. LSJ Shortblock. What parts can I use from 2.2L
  241. I told myself I'd sell it...here we are.
  242. Rebuild Questions.
  243. BLE adjustable lifters
  244. the bag of smits build prelogue stg
  245. ringland failure?
  246. valve height
  247. Flowthrough Tank for track??
  248. no boost lsj help ASAP
  249. Supertech vs OEM valves
  250. LSJ Cylinder Head PN 07012309? 40430709?
