PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Monza Exhaust?
  2. what track times to expect?
  3. what clutch do i buy?
  4. ticking sound on cold start
  5. Reflash code?
  6. Yet Another Newb Methanol Question
  7. methanol question
  8. Meth Standard vs. Progressive
  9. Problem Guys HELP
  10. a/c leakage, in cabin!
  11. ZZP or INTENSE Tune....
  12. So who's done the piston swap?
  13. TTR Products.
  14. Header DP!! no restriction
  15. Smallest Pulley?
  16. Stage 2 install
  17. ZZP Shorty Header..??
  18. Building my 2.0L and going turbo. need help
  19. Best "Bang for Buck" After Stg 2.
  20. clutching grabbin high
  21. Dual Pass have to go with H/E?
  22. GMR cams and stage 3...?
  23. Dyno Results.
  24. Ordering my Exhast NOW!?
  25. Aftermarket H/E Void Warranty?
  26. Hydro shield?
  27. return style fuel system
  28. Vibrant Header/Downpipe bolt size?
  29. Oil pan issue!
  30. The Cooling Mod Build...
  31. Lets Talk 60lbs Injectors...
  32. throw out bearing?
  33. little help with stage 3 cobalt stuff
  34. help plz
  35. i need a little help
  36. 2.6" or 2.7"??
  37. Switching my intake... Diff in Hp?
  38. Knock sensor...
  39. 2005 to 2006 revision list?
  40. Just Ordered my R.A.W. Intake
  41. H/E Question
  42. is 2.5 unsafe
  43. Stage 3 + Nitrous
  44. whats the best cooling mods?
  45. clutch issue
  46. Cryo treating
  47. CEL: EVAP System?!?!
  48. Hurst shifter wobble
  49. Larger throttle body problems
  50. Curious between these two options
  51. Any Ideas?
  52. Meth Questions Yet Again ?
  53. Hand brake got loose
  54. Which Cold Air Intake to go with.
  55. Problems...
  56. Save Me
  57. 2.7 pulley without shaving snout?
  58. Proper Break In
  59. installing pully tensioner
  60. changing oil in supercharger?
  61. Getting power???
  62. Where is the ss/sc heat exchanger reservoir?
  63. tranny fluid
  64. would like some opinions.....
  65. Cooling Mod Meltdown!!!
  66. Belt Shredded
  67. diagram for heat exchanger
  68. ZZP 2.5" Downpipe
  69. Difference between 2.9 and 2.85 pullies.
  70. meth questions
  71. Gains from building the motor?
  72. stock pulley
  73. need some part numbers..
  74. I've Searched But Need A Good Set Of Racing Valves
  75. Space under hood????
  76. megan?
  77. Stupid Question
  78. Tvs
  79. megan muffler replaces by magnaflow
  80. Quick Question
  81. My poor balt is bleeding s/c oil
  82. Bought a cutout
  83. whp estimate
  84. JBP Headers
  85. Question
  86. throttle body
  87. Question for those with heat exchanger.
  88. Need to clean throttle body
  89. modders vendors everybody!!! help me if you can!!
  90. timing belt noise
  91. gt35r
  92. Electirc cutout
  93. problem with timing
  94. thought everyone would enjoy this...
  95. Lower Intake Mani upgrade
  96. Lower pulley
  97. ?What temp does H/E pump
  98. main and rod bearings
  99. What would cause a Spark plug to melt?
  100. Intake and pulley
  101. Installing Diamond Pistons...quick question.
  102. stock rings on diamond pistons?
  103. Stage 2 Reflash again?
  104. Rebel intake owners...
  105. Harrop Supercharger
  106. i need some help.....
  107. TurboTech Racing Solid Mount Review
  108. Few New Parts on the Turbo Balt *PICS*
  109. Better Supercharger???
  110. warping with meth
  111. Loudest Idle
  112. Staged Supercharger
  113. I need help
  114. ZZP Shorty header
  115. Oil cap breather.
  116. Meth Questions/Help
  117. Just say NO! to street tuning
  118. ok, what do you guys think?
  119. Option B + Dual Pass Question
  120. Stage 2 installed, rpms "hanging"
  121. Hatrickstu Cooling Mod Pics
  122. Exhaust tone with header??
  123. HELP....need security bolt
  124. help buying a header
  125. code 496 high purge flow fault help me
  126. MAX whp on the M62 with a BUILT motor?
  127. Plugging M62 Silencer holes, thoughts about Permatex Cold Weld?
  128. ZZP Mid-length header/downpipe - nothing but problems
  129. compatibility between 2005-2006
  130. Need help taking up serpentine belt space
  131. The REDLINE lives!!!!
  132. ZZp Header gasket
  133. Anyone recommend these solid mounts?
  134. option B...
  135. Changing tranny oil
  136. exedy hyper-single install?
  137. wideband?
  138. Intercooler sprayer fastener?
  139. Things needed for Poly Urethane Transmission Mount Swap
  140. Ported lower intake.....
  141. sea level tuning
  142. Changing the oil in the superchager
  143. ? about supercharger
  144. 08 ss/tc grill fitting?
  145. Pulley size
  146. how? water meth????
  147. I need a turbo manifold
  148. 2.8 n 42's????
  149. Anyone know if the GM Stage 2 Hub will fit the Nate's 4 bolt pulley?
  150. Help w/ tensioner pulley please.........
  151. Oil
  152. Achievable (WHP) Goal *Ideas/Opinions Please*
  153. Does anyone know the exhaust dimensions?
  154. Option B Kit
  155. can anyone with gm stage two help me....
  156. difference in stock and aftermarket downpipe
  157. More reassurance - meth maintains 100 octane mode on stage 3
  158. exhaust way too loud!
  159. which way is better?
  160. what gear?
  161. TVS experimenting again
  162. help???
  163. Tuning Problem?
  164. better struts?
  165. 06 ss/sc exhaust
  166. Smaller Pulley, Bigger inj., tune, tensioner belt THURSDAY!!
  167. Intense stage 3
  168. Twin Charging noob questions.
  169. Need advice...
  170. hungryhip-ccp level V hahn turbo build with pictures. (56k stay away)
  171. putt putt
  172. Something i want to know...
  173. Louder Whine???
  174. Ingalls/Poly trans mounts
  175. What Pulley you can run with GM STAGE TUNE! (Informational Thread)
  176. RDFabs 3-inch Intake
  177. A better intercooler pump
  178. Boost Gauge???
  179. Rear engine seal?
  180. Other cheaper turbo set ups then hahn?
  181. pulley swap impossible
  182. Turbo Suggestions
  183. Rotor and pad change HELP!
  184. ss/sc turbo swap down for now
  185. Voids Warr.
  186. with a bigger heat exchanger
  187. CA 2.79 pulley and GM Stage 2
  188. Can i run this H/E in the winter?
  189. MRZ Crank Pulley Review
  190. Heat Difference 2.5" vs 2.8"
  191. Readouts for Interceptors?
  192. Help understanding all the HEAT EXCHANGERS (information thread)
  193. wideband
  194. heat exchanger
  195. Where to find muffler?
  196. Nitrous question?
  197. Rebel Build
  198. SPEC Stage 4 for sale. $750 INSTALLED!!!!!
  199. Exhaust/muffler opinions...
  200. What should my next mod be???
  201. Stiegemeier Sc porting
  202. Exhaust persuit
  203. turns over but doesnt start!!!!!! WHATS WRONG
  204. Gauging vendor interest. (COOLING MOD)
  205. Need some help.
  206. Which oil to use
  207. Spool time
  208. pulley power drain
  209. Oil accumulator - where to tie in
  210. my intercooler pump
  211. Help please!
  212. Will I be OK with stock exhaust and this setup?
  213. Broken Transmission Question
  214. M62 and Manifold bolts
  215. Aeroforce interceptor question
  216. 60lbs Injectors
  217. Injen Filter
  218. Finally got the oil catch can done
  219. s max performance products worth it?
  220. 2.8 and 60lb problems after install
  221. smallest pulley size on stock tune???
  222. Joining the ranks of Stage 2...
  223. daily driveable?
  224. custom steel exhaust...
  225. going to home depot need help please!
  226. Something Weird from GM Site...
  227. How much HorsePower should I expect.
  228. motor movement
  229. 2.85 with stage 2
  230. Help!!
  231. different years different stuff?
  232. what clutch
  233. snoud??
  234. centerforce clutch?
  235. short throw shifters?!?
  236. LSJ Important Warning!
  237. Oh So Ricey....
  238. Back pressure
  239. went from 3" to 2.5" exhaust picked up 16hp
  240. would it be worth it??
  241. Evap System Not Complete...WTF?
  242. Best Valued kit with 60's?
  243. stage 4 my cobalt!!
  244. Tech 2 help.
  245. 2.8inch pulley, 60lb injectors, stage 3 spec clutch and flywheel and ngk spark plugs.
  246. notch required on header for egr?
  247. got my header!!
  248. vibrant resinator
  249. Am I stock?????????
  250. Cai?
